TwinTurbo.NET: Nissan 300ZX forum - What is the benifit of deleating the PTU? (n/m)
ZUL8TR
on May 13, 2015 at 1:32 PM
Yup, my detonation sensor wire corroded 1" back
posted by flashstar
on May 13, 2015 at 01:02 PM
First plenum pull, any suggestions for the harness?
YlwPrlZTT
21:57:51 05/12/15
Re: First plenum pull, any suggestions for the harness?
Bo (Houston)
22:26:20 05/12/15
Cut Out the Old Harness and Install a New One
flashstar
22:50:41 05/12/15
Can it be done with the engine in? (n/m)
YlwPrlZTT
22:55:07 05/12/15
Yes, but many suggest removing transmission
spicyZ
10:54:18 05/13/15
I've done the entire job with only the plenum removed
flashstar
12:31:23 05/13/15
Did you have to pry bar the hole in the firewall
spicyZ
09:37:34 05/14/15
Nope, I just wrapped the connector tightly with electrical
flashstar
12:28:51 05/14/15
You could do the ultimate cheap route.
Goldchocobo
23:03:51 05/12/15
Assuming the junker connectors don't fall apart>>
ZUL8TR
04:08:56 05/13/15
I will definitely try going that route. Thank you. (n/m)
YlwPrlZTT
08:47:54 05/13/15
When doing injectors see link>>>>>>>>>>>>>>
ZUL8TR
09:08:29 05/13/15
Just find the nice ones
Goldchocobo
09:22:54 05/13/15
more benefits to a new harness than just connectors
LivinTheDream
11:25:54 05/13/15
flashstar
13:02:45 05/13/15
What is the benifit of deleating the PTU? (n/m) -
ZUL8TR
13:32:29 05/13/15
"sub harness" because less corrosion points (n/m)
LivinTheDream
13:57:06 05/13/15
and it's off!! I feel accomplished :-)
YlwPrlZTT
23:16:33 05/13/15
good job, now get some tape over those intake ports (n/m)
ZUL8TR
04:32:01 05/14/15
Android300zx
04:48:34 05/17/15
